The firmware upgrade of cloud platforms does not distinguish between online states, and can also create upgrade tasks for offline devices. When the device goes online on the platform next time, it will receive an upgrade task from the platform to perform the upgrade operation.
After offline devices issue firmware upgrade tasks, the firmware upgrade status will change to "waiting". If you do not need this upgrade operation, you can cancel it in the task list.
