EC312 Enables Generator Remote Monitoring & Operation Maintenance
Generators deployed across scattered locations relied on manual on-site inspections. This caused delayed access to operational data (e.g., speed, oil pressure), slow fault response, and high labor costs for routine maintenance.
InHand EC312 Industrial Cellular Modem — supports stable 4G/5G connectivity, RS232/485 interfaces for sensor connection, industrial-grade durability (resists extreme temps/vibration), and secure data transmission.
Connect EC312 to generators’ sensors and controllers to collect real-time data (speed, oil pressure, fuel level, runtime, fault codes).
Transmit encrypted data to the remote monitoring platform via cellular networks for centralized oversight.
Trigger instant alerts for anomalies (e.g., low oil pressure) and enable remote parameter adjustment.
Manual inspection labor costs reduced by 65%.
Fault response time shortened from hours to 15 minutes.
24/7 real-time generator status monitoring, improving operational reliability.
