How do I access the Web management interface (IEOS)?
The EC312 features a pre-installed IEOS system that provides a Web-based management interface.
Connect your PC to the ETH2 port and use the default address:
https://192.168.4.100:9100.
Note: IEOS uses port 9100 for HTTPS connections; standard ports 80/443 are left open for user applications.
