How does the device's Sleep Mode work?
The VT310 uses a state machine with three modes: Run, Temp Run, and Sleep.
It enters Sleep mode when the vehicle ignition (IGT) is OFF or external power is removed (voltage drops below sleep threshold).
It can be configured to wake up periodically using the Wakeup Interval (default 120 min) or remain active for a set Wakeup Runtime (default 5 min) before sleeping again.
