How to configure a static IP for the IR900’s Ethernet WAN interface?
1. Go to [Network > Ethernet Port] > Select the target interface (e.g., Fastethernet 0/1). 2. Choose "Manual" as the connection mode. 3. Enter the static IP address, subnet mask, and gateway. 4. Click "Save"— the settings take effect immediately (no reboot required for Ethernet changes).
