How to configure serial data bits and parity bits for InRouter302?
Log in to the web interface → [Services → DTU Settings], select the target serial port (such as COM1), set the data bit (default 8 bits) and parity bit (none/odd/even), save and adapt to the communication requirements of the serial device. The device is capable of forwarding data from the serial port to the server configured by the user
