How to enable dual-SIM auto-switch for cellular connectivity?
1. Navigate to [Network > Cellular]. 2. Enable "Dual SIM Enable". 3. Select "Main SIM" (SIM1 by default). 4. Set "Max Number Of Redials" (default 5— the device switches to SIM2 if SIM1 fails to dial). 5. Save settings— the gateway will auto-switch to the backup SIM for uninterrupted connectivity.
