How to enable SSH remote login function for InRouter615?
Go to the web interface ->System ->Service Management ->SSH Settings, check "Enable SSH", set the login port (default 22, customizable), save it, and then log in using a terminal tool (such as Xshell) by entering the device IP, port, and account password.
