How to set a static IP for the EC3000’s Ethernet interface?
1. Access the web interface (default LAN IP is usually 192.168.2.1, check the nameplate). 2. Go to [Network > Ethernet]. 3. Select the target interface, choose "Static IP", and enter the IP address, subnet mask, and gateway. 4. Click "Save" to apply the setting.
