How to set the priority of cellular and wired networks for 5G CPE02?
You can edit WAN and Cellular interfaces in the "Internet>Uplink List". You can also adjust the priority of each interface by dragging the "Priority" icon. Interfaces are arranged from top to bottom based on their priority, with higher priority interfaces determining the current upstream interface for device operation.
