InHand IG502 Enables Remote Monitoring for Small-Scale Sewage Treatment Stations
Small-scale sewage treatment stations are geographically scattered, making centralized management challenging. Manual on-site inspections are costly, fault detection is delayed, and operators lack real-time visibility into daily treatment volume and plant operating conditions.
InHand IG502 Edge Computing Gateway — supports standard MQTT platform integration, custom data packaging and parsing, and industrial-grade durability, perfectly suited for decentralized sewage facility monitoring.
Connect IG502 to on-site sensors and controllers to collect real-time data (flow rate, water quality metrics, equipment status).
Use IG502’s custom data packaging and parsing to format raw data, then transmit it securely to the cloud platform via MQTT.
Enable centralized remote monitoring of all stations, with automatic alerts for abnormal conditions (e.g., equipment faults, flow fluctuations).
On-site inspection costs reduced by 60% (no more frequent manual visits).
​Fault response time cut from 24 hours to 1 hour (proactive alerts enable rapid action).
Full real-time visibility into treatment volume and operating conditions, boosting operational efficiency by 35%.
