Urban water supply/sewage facilities (pumping stations, treatment plants) are scattered, with pain points: no real-time visibility into water quality/equipment status, slow manual data collection, and delayed fault responses.
InHand IG902 Edge Gateway – supports industrial interfaces (for PLC/HMI connection), MQTTs secure transmission, edge data preprocessing, and industrial-grade durability (suitable for treatment site environments).
Link IG902 to on-site PLC (controls pumps/valves) and HMI (local operations) to collect data (water pH/turbidity, pump pressure/flow).
IG902 preprocesses data locally, then transmits it to AWS cloud via encrypted MQTTs (over the Internet).
Trigger instant alerts for anomalies (e.g., high turbidity, pump overload).
24/7 real-time monitoring of water/sewage processes.
Fault response time reduced by 60%.
Manual data collection work cut by 70%; operational efficiency up 35%.
