InHand IR315 Powers Reliable Connectivity for EV Charging Stations
EV charging stations faced connectivity challenges: unstable single-carrier networks caused failed payment transactions, lack of remote monitoring led to delayed fault detection, and unencrypted data transmission posed security risks.
InHand IR315 Industrial 5G Router — supports 5G/4G Dual SIM redundancy, VPN-encrypted data transmission, industrial-grade durability (wide temperature range), and remote management, ideal for outdoor charging environments.
Connect IR315 to each EV charger to enable 5G/4G cellular connectivity for real-time transaction and status data transmission.
Use Dual SIM redundancy to automatically switch carriers if signal weakens, ensuring uninterrupted payment processing.
Encrypt data via VPN to secure payment information; enable remote monitoring of charger status (e.g., charging speed, fault codes) and over-the-air configuration updates.
Payment transaction success rate increased to 99.9% (eliminated connectivity-related failures).
Fault response time reduced from 4 hours to 30 minutes via remote alerts.
Maintenance costs cut by 50% through proactive monitoring and remote troubleshooting.
