Hi,
under integrations, I created mqtt event type with event type connect, disconnect, device.info, series, lbs to test a device which is under Gateways (selected a single device) and I tried to test rebooting the device from Gateways page in order to see the disconnect and connect message from mqttx.
However, disconnect or/and connect messages are not showing in the mqttx even though i have subscribed to all ex. inhand/# and inhand/+/+ (for my uses case where its inhand/device_id/event
here is my setting for the mqtt integration from inhand:
