Hello,
we are using the Device Supervisor on an InHand InGateway IG902
to retrieve data from industrial PLCs to our Thingsboard server.
We are having a problem configuring one of the machines we need
to monitor. The machine has an OPC-UA server, but the nodes we
need to read use node ids of type GUID. The Device Supervisor
software unfortunately only allow us to configure node ids of type
String and Integer, so we are unable to create a proper
configuration. Is there a way to read OPC-UA nodes with GUID ids?
An example of such a node id would be
"ns=7;g=39d57d24-0002-f723-bb9d-f30869266fcd". As far as I understand, there is currently no way to get data
from the nodes we need. Are we missing something?
If it's not currently possible to read such nodes, would it be
possible to have a fixed version of the Device Supervisor with
this functionality?
