Step | Action | IG502 Feature Utilized |
Connectivity | Connect Siemens S7-1200 PLCs via Ethernet and legacy Modbus sensors via RS485. | 2x 10/100Mbps Ethernet ports and RS485/RS232 interfaces. |
Conversion | Convert PLC and sensor data into standard formats using a "zero-code" approach. | DeviceSupervisor Agent (DSA) service. |
Intelligence | Run custom Python scripts to trigger local alarms if a machine's vibration exceeds safe limits. | Python secondary development platform. |
Transmission | Send optimized data to the corporate cloud via 4G LTE or Wi-Fi. | Global cellular access and Wi-Fi/Ethernet failover. |
Management | Remotely update gateway firmware or monitor connection status. | InHand DeviceLive and Device Manager cloud services |
