Use Case: 5G Broadband — The "High-Speed Engine" for Smart SMB Offices
Background
With the widespread adoption of digital workflows, Small and Micro Businesses (SMBs) are increasingly relying on cloud collaboration, video conferencing, and IoT devices. However, traditional fiber network deployment relies on physical cabling, resulting in long construction cycles, high costs, and poor flexibility. This is particularly challenging for SMBs in rented office spaces or temporary sites, where deployment efficiency directly impacts business continuity.
Requirements
  • Rapid Deployment: Immediate network availability is required without the delays of physical cabling.
  • High-Density Connectivity: The network must support 128+ concurrent terminal connections, ensuring zero lag for video conferencing and large data transfers.
  • Intelligent O&M: A visualized platform is needed for remote network management to reduce reliance on on-site IT manpower.
Solution: 5G CPE02 Unified Access
Deploying the 5G CPE02 as the network hub creates an integrated "Ultra-Fast Access + Cloud Intelligence" solution:
  • Zero Cabling & Instant Networking:
    The 5G plug-and-play design requires no professional configuration. Full office network coverage can be achieved in under 1 hour, saving 90% of the time compared to traditional cabling.
  • Smart Scheduling & Service Prioritization:
    Wi-Fi 6 High-Density Architecture: Utilizing 2x2 MIMO antennas and 3000Mbps bandwidth, the system segments traffic into an "Office Channel" (Prioritizing Cloud ERP and Video Conferencing) and a "Guest Channel" (Rate-limited basic access) to prevent resource contention.
  • InCloud Service for Visualized Operations:
    Administrators can view real-time traffic, signal strength, and device health for all terminals. The system provides automatic alerts for anomalies—such as uplink errors or reaching SIM data limits—allowing for timely intervention to ensure efficient enterprise collaboration.
