1. Scene background
There are hundreds of buses in Suzhou, and the monitoring, positioning, passenger Wi Fi, and onboard equipment used to be "separate": surveillance videos had to be sent back to the station to guide, and drivers had to be manually called to ask where the vehicles were and if there were any faults. Passenger Wi Fi was often disconnected, and these decentralized systems made dispatchers dizzy and always missed seeing vehicle problems.
2. Product selection
VG814 gateway (specially adapted for public transportation mobile scenarios, capable of connecting multiple devices such as monitoring, positioning, Wi Fi, etc. simultaneously, and also supports 4G/5G and APN dedicated networks)
3. Core issues
The monitoring, positioning, Wi Fi and other systems in the car are scattered and cannot be managed uniformly;
The vehicle status (such as faults and location) cannot be viewed in real time, resulting in low scheduling efficiency;
Passengers' Wi Fi relies on regular networks, which can easily disconnect while running.
4. Solution
Connect all the monitoring cameras, GPS/Beidou locators, passenger Wi Fi, and other devices on the vehicle to the VG814 gateway, and transmit their data through the gateway in a unified manner;
Real time data transmission from the gateway to the cloud platform: monitoring videos, vehicle locations, and device status are transmitted directly to the cloud platform of the bus dispatch center through the gateway's 4G/5G network, and dispatchers can view them all on their computers;
Stable signal with APN dedicated network: The gateway connects to the dedicated APN network of the bus, and regardless of how fast the car is driving, passengers' Wi Fi and data transmission are not easily interrupted.
5. Implementation effect
Dispatchers no longer need to "search around": they can simultaneously view vehicle location, monitoring screens, and equipment status on the cloud platform;
Fast response to vehicle malfunctions: If the device encounters a problem, the gateway will automatically alert, which is earlier than manual detection before;
The passenger Wi Fi has become much more stable, and customer satisfaction has increased.
