What is the OTA Upgrade feature, and how does it work?
OTA (Over-the-Air) Upgrade allows remote firmware updates for devices without physical access. To use it:
- Go to the "OTA Upgrade" menu, select the target device(s), and upload the firmware file.
- Choose to upgrade immediately or schedule a time.
- The device will download and apply the update when online, ensuring minimal downtime.
