If you purchased an IR305 or IR615 from Verizon and trying to find the WiFi password for SSID: inhand, please try inhand123 as the password.
If you are using an IR305 from Verizon, please check out this article for fixing slow upload speed issue:IR305 from Verizon Slow Upload Speed/ Trouble Connecting some Applications
